Twisting the wires wont help with this stove, the thermostat is required for operation. There is no way around it, all stove setting are contained within in.
what are the letters
and I read on another forum that they had the same problem and he removed the stat from the wall bracket and then replaced it and it worked for him its worth a try
typically you should twist red and white together not red and green
The Mt. Vermin has a Stat All of its own.. Not compatible with Any other system. The stat is part of the computer that tells it to do what and when.
Untwist the wires and put everything back together as normal, ensuring the wires are color coded correctly. If that does not work, I like the suggestion of cutting the ends of the wires and stripping new ends. Maybe you were having connectivity issues.So then sounds like I need a new Tstat?
You may be looking at a new Tstat...
I'm guessing he had it off when he was farting around with the tstat wires.Did you try to remove the thermostat faceplate and then reinstall it. If it went blank from static electricity that should fix the problem.
Update: The dealer came out today and it was the tstate. Well at least I am back up an running. Can't wait to get that bill
Did he mention if their were any tricks you could of done? Or its dead its dead, no heat
glad its working and hope he is easy on the bill. What is the humidity in your house? static electricity is a possible suspect that fried the T stat. If its low make sure you rub your feet on the carpet and zap a family member before touching it again. or add a humidifier.
HOw long have you owned the stove? Might be warranted? I have heard the stats go for $400 plus.
Glad to hear you are fired up! When mine was down for 24 hours because of the autoclean, that first fire was so gratifying.
did he let you keep the old one?
I'm no electronics expert but I'd be looking damn hard at trying to fix it.
yeah I'd def want that bad boy.You know I am not sure, the wife was here when he came as I was at work and I never asked her. I have not seen it so I assume he did take it. Good point never thought of that, will have to call tomorrow and see if he will give it back to me. Do not see why he would want it, most likely took it just to be nice.
yeah the dealer probably will fix it for 10 cents no wonder he took it
