goosegunner said:ABC1 said:I have calculated the flow for the runs using Tennman's spreadsheet (a great tool, thanks!) and can just get by using 1-1/4 PEX and a BIG CIRCULATOR. My first choice was dual runs of 1" PEX encapsulated in 3 lb. spray foam but the work and cost gets large. The 1" PEX can be had for $0.50/ft in large quantities but the foam will be about $1400.00. There is also the complication of insulating the entrance in the foundations of the 2 buildings to recieve heat. With this method at approximatly $2000.00 I am still looking at others. I have seen 1-1/4" Watts Triple Wrap foam in 4" Drain Tile for $5.00/Ft. Does anyone have any experience with this type of pipe? It certainly doesn't look as well insulated as the $12/ft pipes but will it work adequatly in the North East?
You get what you pay for, if you want to do it again in a year or burn a lot more wood go ahead and use it.
