Bruce2500
I have the original limiter with the added washers underneath. I have a laser heat gun and the cutout temp on the stovepipe surface under the disk is around 420. If the temp would stay there I'd be fine but that's my problem, the disk opens up at 420 and resets at about 170(it takes that long). If I set more space and had the disk opening at 500 or whatever, once the damper opened the stove would climb there and shut down and cycle, regardless of the boiler water temp. I jumped the switch out once and monitored the temp, it climbed to 700 no problem, probably would've gone more had I not stopped it???? My aguastat also is adjustable, I keep it at 180. I set the oil burner to 145 when running the wood boiler. Thanks for the response.
