Wood that sits out in the rain sure ain't dry but it sure is 2 days later when the sun comes out.
Wrong. loose bark traps moisture.
Wrong again - been there, done that, still does't burn right after 7 days.I think the only value in top covering is if you need that particular wood in the next 7 days.
I am not "wrong" that is my opinion based on years of doing just so.Wrong again - been there, done that, still does't burn right after 7 days.
It must be a climate thing.
Wrong again.I am not "wrong" that is my opinion based on years of doing just so.
Cant believe the "climate" in Ma in that much different, I can remember years were we had all sorts of rain and flooding and my wood was fine, the only time I have ever had mushrooms was on some punky wood that held moisture. Sure loose bark traps moisture but it dries out fairly quickly, it is quite windy here most of the time but not so much in the summer but maybe more so than where some of you are at.
I cover an uncover to keep the varmints out. Makes the stacks less hospitable to them. My set up, takes me a few minutes max, morning and evening. Do it before the dog's first walk, and after his last walk....It is a pretty well accepted fact that the eastern states do need to cover right after splitting. As you move west, we do not get nearly as much rain as the eastern states. We have a son living in PA and it is amazing to us just how much rain falls out there. Most of the time when it rains here, it rains for that day or at most, 2 days. That is usually followed by some strong NW wind that is really dry and indeed, less than 24 hours after a big rain, our wood will be dry. Wood is not a sponge unless it is punky. So it takes a lot of water to soak into stacked wood....but it can happen. So it is not costly and does not take much time to top cover the wood. However, I shudder every time I hear of someone covering wood when it rains then uncovering. Then covering again. That would get tiring very fast! Just top cover it and leave it. Let the wind do the drying.
You get a pass because you live in Washington state.It rains here October to May. No way I'd leave my wood out without covering it.
fire_ man you you are getting wiser by the dayDennis makes a good point. (He has been known to do that on occasion)
Out East we get days, sometimes a full week of rain, and then to make matters worse it can stay sticky, humid and windless (and cloudy) for days. My situation is even worse again since we have hills blocking the wind and lots of tall trees blocking the sun.
So bottom line: Do whatever works for you.
