Thanks!
The 30 is already working. Yesterday the high temp was 72. Today, 82.
I'm not worried about that, really. It is completely over-sized for my needs, so 10 hours of heat should be doable.Forget whether the shirt fits... I hope the stove fits your needs.
Actually it was an honest question. My downfall in the shop is the TONS of steel, the 4ft cement walls, cement floor...Its a biotch to get that sucker up to temp if it has been zero out for a couple of days.Nah. They don't heat very well Jags. I just have a bunch of IDs here to trick BrowningBar into buy that stove.
My work here is done.
How long can the home made monster burn with one feeding?
The guy that runs a forge next to me has a giant stove dead center of his workshop that is probably the same size as yours. It heats, but it also eats.
That is EXACTLY the reason for the consideration of the 30. I have NO doubt that the 30 will nibble wood compared to what I am running now. The hungry bastage. The only advantage to the big beast is its ability to bring the space up to temp fairly quickly.
Right, but, if the 30 can burn overnight, you might not have to burn out as much cold every day.
