Rich L said:
wellbuilt home said:
LargeHearthstoneOwner said:
We bought a hearthstone equinox last summer (summer 08) and had it professionally installed. We love the stove but YES WE TOO had problems with the air intake valve handle getting stuck especially when the stove is running hot. It gets stuck at the two extremes and in the middle too. (BTW jiggling worked early on but now if there's a fire going 99% of the time jiggling does not work. Last winter it got progressively worst and then got stuck semi premanently even when the stove was cold with no fire. We complained regularly to the store while still under warranty and had the store's and a hearthstone worker here last spring and they did something......filing it down (I think) and we thought it was fixed but now another winter and guess what?......now the problem is back and we're no longer under our warranty. This is a pain and a bummer since we complained about it all last winter while under warranty and they took until spring time to get the right people available to come out. Looks like the fix effort in the spring was not the true test we needed or else this is a very annoying recurring problem in the design that everyone should know about. I'll plan to reread through these comments in more detail to see if maybe we can do something ourselves.
We run 24/7 for two months of the winter so at least we're luck its mostly been stuck to the right. Suggestions? jane.
I have no problem with air control yet . I'm still sliding smooth .
My problem is out put , It seems like i need to keep my fire box full to keep the stove top temp above 450o .
My stove will burn at 300o stove top temp but to get hotter i need to keep the stove full.
Ive burned up 31/2 cord of wood since November ? seems like alot .
I heated my house with a Dutch West cat stove and had no problem . 3000sf 24/7 burn 31/2 to 41/2 cord a year .
its 12o now and I'm at 67 in the center of the house . I'm sitting 5' from the stove and its cold .
any one having a problem with heat ? John
Hey Wellbuilt in a recent post entitled Equinox you said your stove was working well now this.What's going on?
I don't know if I'm having a problem ?
The thing is i just looked on the side of the house where my wood supply ( was) and its all gone .
I had all dry oak that was standing dead for years with the bark gone cut and split last winter stacked with the top covered .
Ive stacked wood in the same spot for years and always had lots of wood left over .
My problem is I'm burning way to much wood and the family is fighting over the blankets wile watching TV.
The house seems to stay around 65/67o when its 20 out side.
I'm sitting in a room 5' from the stove with one outside wall 2 2'x2' windows ( room size 16x22 10' ceiling )with the stove in the center of the house and my feet are freezing .
Ive heated this house with 6 different stoves and was never cold in my chair.
Ive used a fisher that i could burn logs in .
VC vigilant wood and Cole units 1980s
VC defiant 1980s and newer cat stove .
Consolidated Dutch West
Every thing being equiel i think the DW gave better heat with less wood .
Im adding a large famly room this year and i swaped out my DW for a larger stove to heat the extra space but the way it looks i will be getting a second EQ for in the new room. John
