Slow1 said:For folks who don't recall/use this trick. A while ago someone (sorry, I don't recall who) on this forum made a really good suggestion on how to know what the peak temperature your stove hit while you were away from it if you are using a stove top thermometer. I've been using it ever since and it is simple and very low cost...
Simply take a piece of foil and fold it so that you have a small V shaped piece and place it in the groove of the thermometer on top of your stove ahead of the needle. Make this foil small and light enough to be easily pushed by the needle as the temps rise, but heavy enough to not be easily blown off (i.e. more than one thickness is my suggestion). Then before you leave the stove gently nudge it against the needle so that as the temps rise it will push the foil up. When the temps go down it leaves the foil at the 'high temp' mark and you will know what it was.
Anyway - using this method you can know what the peak temp was on your overnight/day burns. Clearly you won't know when or how long that peak temp was. But it can be interesting to know if you are peaking higher than you expect.
My experience with my VC was that it would peak much higher than I expected many nights and I was unable to predict when/why etc (part of why I lost confidence in the stove).
With my current FV I have found that it tends to peak early on and then stay pretty steady with a slow rise for the first hour or so. Like someone else posted I did find that I would get a second peak/spike about an hour or so after feeding when I was using less well dried wood. Then again last year was my first year burning with it and my wood was VERY mixed so things were changing constantly between my experimenting to try and figure out how best to burn and the variability in the wood I'm not sure I really had a predictable pattern. But in any case I never saw any high temperature peaks that alarmed me.
I already beat you too it Slow1 :snake: :roll:
