No plate! Just a burned paper label that was poorly ripped off. I checked that before to get the model, etc to find the manual.
vizzle said:No plate! Just a burned paper label that was poorly ripped off. I checked that before to get the model, etc to find the manual.
BrotherBart said:The stove is the Century Hearth S244E.
(broken link removed to http://www.vermontcastings.com/content/products/productdetails.cfm?id=204)
BrotherBart said:I think that some bricks need to be replaced, pipe fixed up, wood man straightened out and the little stove fired up for the season.
If the wood guy won't cooperate get a cheap chop saw and cut'em all in half. Load'em half N/S and half E/W.
BeGreen said:BrotherBart said:The stove is the Century Hearth S244E.
I thought it looked like a Century. The bad news is that this is the same size firebox as the 13NC. If so, it kind of brings me full circle back to the wood. Your thoughts?
vizzle said:BrotherBart said:I think that some bricks need to be replaced, pipe fixed up, wood man straightened out and the little stove fired up for the season.
I tried to cut them before, its a bear! Am I doing it wrong? Or am I using the wrong saw? Once they are split, a chainsaw is almost unsafe to use because of the movement in the pieces.
BeGreen said:Have you looked into options for tightening up the heat leaks in the house? Now that we've established that you already have a 1.8 cu ft stove and that you are still cold, maybe it's time to invest in some attic insulation and caulking instead of a new stove? Done right, that will save you money and increase your comfort year after year. Just a thought.
