Diabel said:Good idea!
That stove might be a bit too much for a room that size..
trailblaze said:BeGreen said:Time to shut her down, the walls are getting too warm. Seems like a wall shield is in order.
Can you be more specific about the location of the temperature readings in relation to the stove? It would also be good to have specific distances listed so that other CDW owners can assess their options for corner installations.
the walls are hottest ( 183) near the level where the top of the side load door is and slightly upwards, but once i clear the stove height and just follow the stove pipe... they drop to 130's by the ceiling
the left side rear corner is 14.5 inches to the wall.... as you can see in the pics, the left side only is closest to the wall at the rear most left side...
going straight out the back and from the right corner i'm at 21" -18" from the top/ rear edge of the stove top, now as it goes to the right side the rear heat shield get closer by 2-3 inches... but the wall back there peaked about the same height as the left side but at 174 degrees....
trailblaze said:yeah i'm thinking the stove is whats heating it up too hot.... i think a stove pipe shield for 35 bucks would help a little, but the biggest thing is to get some wall shields just off the floor to about 6-8 inches above my stove height....with a 1" air gap...
think that will do the trick to make this safe?
now for the material.... tile, metal, rock??? hmmm
