Hello,
I recently bought an uninsulated fixer-upper house and am living in it while working on it. I bought it off a family that had neglected it. I am getting building permits and going by the book, but it would be great to have more heat in here for the winter.
The house has a brick chimney that is approximately 10"x10" wide, with a heavily cracked uninsulated 6" steel chimney liner going up it that that was hooked up to a now-decommissioned oil heater. There is also a good quality woodstove that was never installed. I am wondering if its a crazy idea to hook the wood stove up to the metal chimnney that used to be used by the oil furnace and heat the house over the winter while it is being worked on. This is temporary, as I will get actual permitted heat in it come spring or summer.
I don't think it is to code, but again this is temporary and honestly a better solution than the original owners had. I already dropped a flashlight down the chinmney and cleaned out the bottom, and there is no creosote on the liner or chimney itself. There is the aforementioned two large holes in it. The chimney is on interior walls.
The chimney is 20' tall and the wood stove will be burning for long periods of time to help with drafting, all I need to do to hook it up is buy a couple feet of stovepipe. I also have carbon monoxide detectors next to it in the basement. I am wondering am I putting myself at serious fire hazard with this temporary fix over the next 4 months?
