Finally outside temperatures in the 40's. Lit the stove, dampered it down, house goes up to 80 degrees. Is my house to tight? It's about 1600 square ft, I put a couple logs in my napolean 1402 and the temperature shoots up. Should I try to burn all day, or mayby let it go out, and relight it after the temperatur goes down? What's the trick to letting it burn all day without over cooking the house. I'm tring to keep the stove temp between 250 and 600 degrees and the house gets to hot How can I regulate teperatures better?
