After reading another thread I am wondering about the heat settings and savings in wood. Once the unit is up to temp and the water is heated, does it make any difference what temp you set the unit at. If it is going to heat the water 5 degrees every time it fires what difference does it make if you are heating to 150, 160, or 170 degrees? It still only heats 5 degrees every time it fires no matter what temp it is heating to. Of course the savings is going to be not heating all the way to the higher temp the first time.
