stejus said:I just picked one of these up because I am taking down about 8 trees next week to expand my back yard to allow more sun in the wood pile area.
Just for giggles, I put the wheels on and fired it up. Took some med size splits to make some kindling. Nice is all I have to say. No more swinging the maul unless I have a stubborn round. After these 8 trees are down and split, it's more or less just re-splitting wood I have delivered.
TomWright said:Hi folks. I have the Homelite version of the Ryobi. I bought the Ryobi first, but it had a hydraulic leak I did not notice till after 3 hours of splitting or so. I returned it to Home Depot, no hassles, but they did not have another one. The next HD down the highway had 2 of the Homelites which are almost identical though claimed at 5 tons not 4. However the HD guy at the second store says they are sold with the same SKU number, so go figure.
Having used a few splitters, (though I am no pro), I am impressed with these little things. They are almost perfect for the average homeowner.
My only real criticisms are that they do not go vertical, and the ram does not get close enough to the wedge to properly finish stringy splits like fresh-cut black birch. Vertical would be great for nibbling at the larger rounds some have mentioned.
Also, if you use them on uneven ground, the pump/controls end needs to be lower than the wedge end. If the wedge end is lower it seems to suck air and not work properly. But level is best. There are a few other things I think could be improved, but that is a different thread.
For the larger rounds, I found if you sledge and wedge them in half first, the Homelite will handle them from there. But I have only done this with rounds that started at about 20-22 inches diameter or so before halving. I suspect they could handle a bit larger.
Since I do not have a garage or shed to store gas in, I use electric everything, including a chainsaw. I find if I start splitting rounds by cutting across the face of the round with the chainsaw, to about 1 - 1.5 inches depth, it holds the wedge, and the wedge starts easier and is less prone to flying off if you mis-hit with the sledge, which seems be more common after an hour or so of swinging that sledge around. at least for this 50 year old desk jockey. And the round seems to split easier.
I make a little assembly line and do one operation each day. I set up a dozen or two rounds on end, score them with the chain saw one day, then split them with sledge and wedge the next day (or two), and then split the half-rounds with the Homelite the next day.
One little tool I have found useful, at least splitting the black birch I am splitting now, which splits kind of stringy, is a pair of garden shears. For the rounds that do not split clean and I can not pull apart y hand, I gut the strings an ribbons between the halves. Easier than wrestling with it or using the chainsaw to finish.
shirlsaw said:Very glad to find this post this morning. Going to go out at lunch today and pick one up. Certainly made me much more comfortable giving this a test run as my first wood splitter. Just need for home use - burn the fireplace for supplemental heat source. Will post an update after my first go round with it!![]()
Lowes has now dropped the price to $249.99 and with a handy $25 off coupon for Lowes from Discover Card now is my time to buy!
shirlsaw said:Ray - Glad you got to take advantage of the lower price! And thanks for mentioning the cooking spray - I saw that and don't want to forget about it!!
shirlsaw said:I was going to pass on the table until I read a few reviews on Lowes website about achy backs! LOL so yes I will be picking that up too!! Thanks for the heads up on the extension cord!
Skier76 said:That's a good price with the price drop. I may have to look into this sooner than later. Thanks for the update guys.
Danno77 said:Quality Craft 4.5Ton splitter from Menards is listed as $238 in the flyer.
Danno77 said:wow, that's a good price. I'm starting to think about it now. darn. I use splitting wood as an excuse to go outside and exercise. Am i going to get fat now? Seriously, maybe the 5tons is weak enough that I'll have a bunch of stuff I HAVE to split by hand. ohhhh, the dilemma...
raybonz said:Skier76 said:That's a good price with the price drop. I may have to look into this sooner than later. Thanks for the update guys.
Just returned from Lowes and the final price paid before taxes was $224.10 lol... They had to treat it as a return so effectively it is a new machine for warranty purposes.. To think I started at $299.00 not long ago and I think it was a good value at that price!
Ray
shirlsaw said:raybonz said:Skier76 said:That's a good price with the price drop. I may have to look into this sooner than later. Thanks for the update guys.
Ray
Wow Ray - you really scored!! Good Deal!!
shirlsaw said:OK - I think I am in love! :kiss: LOL I am VERY pleased with the Task Force splitter. No problem putting it together. Even managed to get it up on the work table by myself. My only personal issue will be remembering to turn the bleed screw prior to using. I need to put a note by the on/off switch to help with that.
Used it both Saturday and Sunday - got half of my big stuff split. That wood pile will be slapped into shape by the end of next weekend. :cheese: That thing sure makes splitting fun (well maybe my mind is warped but sure seemed a more fun option than my other pending projects!). It is quiet and quick - just my style.
If you are thinking about it - go for it while you can still locate one - that is my advice to you!!
