Well I bit the bullet today and bought the Lowes Task Force 5-ton electric splitter today.. At 1st I was impressed how good it looked..
Then I ran some large splits that I had split by hand to a size I could pick up and carry.. The splitter did a pretty decent job especially if the grain was straight.. After an hr. or so the motor wouldn't start and just growled so I suspected the centrifugal start switch not reclosing and the motor was trying to start on the run winding.. I took a small screw driver and the motor turned freely so I tried starting it again and this time it started and ran OK.. Yup the switch in the motor is defective already.. Before you ask the splitter is directly connected to a 20 amp. gfci outlet I installed a ways back.. Had trouble with the motor starting quite a few times and figured I'd return it after today however one split was a bit uneven and when the pusher drove the split into the wedge it bent both pusher rods about 25 degrees and the plastic bearing piece popped out!! Needless to say I am returning this unit for a refund as I feel the bent rod issue will resurface again on a new unit.. I can write off the start switch issue as a fluke but not the mchanical problem.. I will say it is quite powerful for an inexpensive splitter however longevity seems to be a problem.. Called Lowes and they said no problem getting a refund so it's going back tomorrow... These splitters handle pine easily but gnarly oak is a bit of a challenge but it can handle it trying different spots to split it.. Around here oak is very common and is the firewood of choice as it should be.. Bottom line if you buy this splitter be sure your wood is cut pretty squarely or you too will see this same problem...
Ray
Edit: I was pretty aggravated when I wrote the above and I am now considering returning it for a new one.. The manual does clearly state that the logs must be cut squarely and that one wasn't for sure.. I went back outside and split another log and sure enough it straightened the pusher out .. The pusher on these splitters is actually pulled by the ram ... If I decide to exchange it for another one I think I will opt for the 3 yr. extended warranty which covers everything.. Probably a good investment on this item.. While at the store walking with the splitter on the cart I ran into another guy that had bought the same splitter the week before and he loved it and suggested I buy the Werner aluminum work platform which raises the splitter 20" and that works out perfect for the splitter height..
Edit edit: I did return the splitter and Lowes refunded my money with no problem..
Edit edit edit: Couldn't find a better deal and I know Lowes will refund/exchange for 30 days so I went back and bought it again plus the price is now $279.00 instead of $299.00 plus I had a 10% off coupon so I paid $251.00 and took it home and ran the crap out of it and followed someone's advice to use cooking spray to lube it up.. Used it on the pusher slide surface and wedge.. Takes very little and prevents lots of scrapes.. The splitter ran great and handles some pretty gnarly oak and white pine is like splitting nothing.. The problem I had with the 1st splitter motor not starting seems ok on this one..Overall I was pleased how powerful it is for an inexpensive unit and the price is right.. I have split about a cord of oak with it and it has pretty much paid for itself today...I strongly advise buying the $43.00 Werner folding aluminum work platform as it places the splitter at a good height to work from...
Ray
