Hey all hoping we have some carpenters in the group with a good amount of experience working with wood.
I have tongue and groove wood plank paneling that is 6 7/8" wide, 3/4" thick. I'm only about 1/3 of the way done paneling this expansion we put on 2 years ago, as Ive been working on the interior rooms, insulation, wiring, plumbing, exterior paneling, lighting etc - you name it. (only on the weekend by myself).
The paneling that was put up, was put up in various parts of the seasons, from spring > winter with very warm humid summers in between and fairly dry winter. I noticed some paneling that was lined up from one wall to the next was about 1/4 off months later. Oh well. I left what I thought were decent size gaps between edge piece of wood when installed during the lower humidity months. That summer I walked in this room one day, into a bathroom, and there are short runs between two windows next to each other , maybe 10" pieces. They actually expanded and popped my window casing out, and bulged out about 2". So I had to rip those pieces, nail them back and nail back the window casing. Problem solved, or so I thought.
I then went around and noticed I could rubber mallet just about every piece of paneling about 1/8" back toward the wall. Some pieces even 1/4 inch, especially outside wall pieces. I would drop to my knees and give up if I had to remove everything Ive done. I know this is a very humid area, and I have plans to add a mini split and/or a dehumidifier to the crawlspace below to help with humidity. My plan was then to go back painfully and mallet everything back, then re - face nail all my pieces quickly.
Im using 1 1/2 finish nails for 2x4 walls (interior and old house wall) and 2" for 2x6 walls. Everything was face nailed. Which yes I know it isnt the best looking but again, I dont have the time/patience to try and tongue nail. And honestly I didnt even think of it at the time. Which I dont think it matters unless nailing at an angle makes that much of a difference?
I still have the ceiling to do. I was considering adding some panel nails (with heads) every so often to ensure these pieces dont fall from the ceiling some day. I did some test pieces using longer nails , 2 1/2" and appropriate gaps, and they seem to be holding well.
I also wish I went with an eased edge on all the paneling I purchased. Because now you can feel the rough edges of each board when you put your hand up against the wood.
It still looks great. It's poplar, and as the sun hits it, it turns into this almost like cherry like appearance. I did not plan on doing anything with it at all as far as finish. Poly makes things turn orange. I was going to poly the bathroom paneling and that was it.
