sorry no diagram yet but would like opinions. ill do my best to explain
system layout: 2 pressurized loops and a open storage tank
biomass 40 in outbuilding on a 007 pump supplying a flat plate heat exchanger and back to boiler. of course the 3 way and expansion tank and such things. i understand all the tech things like pump placement and that stuff.
The second loop will be the main loop going to the house off the flat plate using a 011 pump ( house has radiant floor, forced air coil, dhw) which will stay on 24/7 .
coming back from the house the main loop will go into a open homemade storage tank with a heat exchanger in it and out of the tank back into the flat plate to pick up more btu's from the boiler loop and back to the house and so on and so on.
Question? will this system be able to store btu's and work at all or am i missing something. (i do understand most of the diff ways of doing this that most of you have done already but just want to know if this will work?) my idea is like most systems to store the heat on one burn a day and live off of the stored btu's in the main house loop (storage).
thanks for any comments i will explain the tank and heat exchanger in it later.
