Hi folks, this is my first post. I'm building an off-grid super-insulated home this summer in Central Ontario and wanted to get your feedback on my system design. We are self-building most of this project on a fairly tight budget.
Site: The house is 2 storeys + basement, 800 sq ft/floor so 2400 square feet total. We have double-stud superinsulated walls so our heat loss calculation came out at 14,000 BTU/hr (17,000 if we don't run the HRV). Available wood on the property is typically Oak, Birch, and Elm.
Chimney: ~27' straight up. The house is oriented south with lots of glazing so we want to take advantage of the passive solar gain. For this reason we planned a masonry chimney with insulated SS liner for the basement and first floor. The brick would act as a thermal mass for storing ambient energy produced by the wood stove as well as passive solar gains, and ideally will "even out" the heating and cooling of the space. The chimney will run up through the middle of the house so going with brick and liner wouldn't significantly change the footprint. We have the luxury of pouring a footing now if we decide to go this route. On the second floor we want to transition to a standard double-wall prefab chimney pipe in drywall chase up through the roof. We spoke with someone who thought the thermal advantages of the masonry chimney may not be worth the expense (footing, brick, mason - or maybe we will DIY?). Any thermal mass / passive solar nerds with opinions on whether the masonry is worth it?
Stove: I'm considering either the Pacific Energy Super 27 or a Blaze King... undecided about whether the advantages of the long, low burn of the catalytic is worth the extra cost in our case. Our advisor also recommended an outdoor air supply, but I've read elsewhere that the advantages are questionable. This will be an airtight house with HRV and no major exhaust loads. We could always install a 4" sleeve and cap it off unless we have drafting issues. Does that make sense?
Since we're off-grid, we're trying to minimize electrical loads like fans to circulate heat. Any tips and tricks for non-electrical ways to move the heat from the basement up to the main and second floor? Main floor is mostly open concept, but second floor has lots of partitions. We will not be finishing the basement ceiling, and not insulating between floors 1 & 2 (I know we're sacrificing some acoustics for this).
Thanks a bunch in advance! These forums have already been very helpful.
