T6 is the syn version.
Is that for a 7.3L? Monster pan on those, 15qts per dump IIRC.Yeah, I looked it up before I posted that last one. Had no idea. Thought Rotella was a food. Pretty much walk into Wal-Mart with blinders on in the oil section. Just need to find the weight of the Mobil one I need and don't even pay attention to the rest of the stuff on the shelf. Found 4 gallons of turbo diesel specific Mobil 1 last night. The teller thought I was nuts when the amount came out to $110.
What oil do you use for winter use then? A zero weight like 0w-30? Had no idea that Rotella was synthetic. Me, I pretty much use Mobil 1 in everything. F350, Mustang, Taurus, Focus, John Deere Z445, and what little I need in the splitter. Don't even have conventional oil in the garage anywhere. For the 2 stroke stuff, I use Stihl HP Ultra but am now thinking about buying a gallon of that stuff and being done with it for the next 20 years.
This is great but then we have
If you really want to run synthetic, get some 10w30 Mobil 1 and call it a day.
So now it's 5w30 or 10w30 ??????![]()
That chart is for one type of engine from one single engine manufacturer. The recommendation will vary amongst the various engines and manufacturers. Really want to know little something about what you pour out of those bottles?This is great but then we have
http://www.upmpg.com/tech_articles/motoroil_viscosity/
Cliff Notes:
0W-30, 5W30, 10W30, and 30wt all flow at similar rates at 100.(Deemed the typical operating temp of the oil.)
One manufacturer's 10W30 might be closer to another one's 5W30 than you think.
More additives and less oil is a recipe for frequent oil changes.And more money spent.
All synthetics are not created equal! There are highly refined petroleum based oils out there (under big brand names) labeled as synthetic through a legal loophole. Buyer beware. The shelf at your local Wally World or parts store is usually dominated by Group III "Synthetics".
I'm getting away from using oil certified to the latest API standards in my small engines. The reason being for that is the formulas have moved to using less anti-wear additives. You won't destroy a small engine running oil certified to SN but there will be more wear on the bearing surfaces and cam lobes over time. That increased wear is deemed "acceptable" (by whom?) and may not be noticed by the vast majority of small-engine operators. But this wrench-monkey has never been one to settle for "acceptable".With a fleet of small engines around, none of which have roller valvetrains (like most modern cars do) and a truck with a big-block Chevy that also doesn't have a roller valvetrain, I look for an oil that will offer the best protection of these engines. There is only 1 Group IV synthetic oil that I know of that offers that protection, and is formulated/marketed specifically for small-engine use.
Don't know how long this has been the case though. Been using Mobil 1 in all my vehicles since 1989. Crazy thing is, I still have all those vehicles. Looks like I am going to need a gallon of Mobile 1 10w-30 Extended Performance for the small engines though. The "cheaper" stuff seems to be working in my vehicles, but don't really want to chance it on my small engines. Will have to keep "Extended Performance" in mind the next time I am at Wally World or the auto parts store.
I would go with synthetic 5w-30 or 10w-30. Splitting hairs on this one for sure.
With that said, synthetics are a lot less susceptible to cold temps.
Been using 5w-30 in my Taurus for years, but now they are recommending 5w-20. The car has 235,000 miles on it on what used to be the wrong oil.
Sorry for the edit, but these are the comments I want to make:
1. It's a small engine. You still should change the oil every 25 hrs (for a B&S, or whatever the manuf. recommends) because there usually isn't any oil filtration on this size engine.
2. It's a small engine. As I said in my post, the rest of the machine usually craps out before the engine. This is one of those (rare) cases where I take the whatever approach. It will be fine with either 5w30 or 10w30 synthetic. The two splitters I use have been running for 15 years on Dino oil (straight 30wt) and splitting about 20 cord apiece every year...and that's with aluminium block flathead briggs engines on both.
On a side note: The 5w20 change on the taurus (assuming you have the 3.0 vulcan) came not because of an engineering change to the engine, but because of needing to reduce friction and meet better MPG requirements. My 3.0 vulcan and my 4.2 essex were both labelled this way, despite earlier versions of the same engines being labelled differently. Both families were getting older and Ford needed to do everything in it's power to get a few more years out of them. They seem to run fine with either, with some people believing that the thinner oil helps to keep the CPS gear from failing. In my opinion, it doesn't matter- they fail with either viscosity oil.
...Sorry for getting off track. I'm a little out of it today.![]()
Well, you noticed the part about my Taurus, which does have the Vulcan engine, but either you missed this:
The most important thing is changing the oil to get rid of the crap that is floating in it, especially on the small engines that do not have an oil filter.
Or you are just reinforcing it.
Poor attempt to reinforce, Though the taurus thing has more to do with my mind being all over the place today- 4 hrs of sleep a night this week isn't working out so good.
Sleep isn't working out well for me either, so I feel your pain. You a tax preparer like me? I can hardly see straight right now and still have about 45 days to go.
I actually have the 6.0l turbo diesel, but it is still 15 quarts. Fills up the entire drain pan. Cannot wait until I get a lift and can use a drum for all this oil.
Changing the coolant is a nightmare. That is gallons upon gallons of coolant.
I run it in my Kubota tractor and my Dodge Cummins.. It's their preferred amsoil diesel over their 15-40w..better shear ability , etc... It's not thickness of oil, it's all about film strength,,, oils ability to keep two metals apart..I learned that as a Harley tech years ago out in Milwaukee...Days of the 60 weight oil are over.. It's all about film strength...What diesel takes 5w-30?
So are you saying that synthetics caused that oil line to break or just bad karma from ignoring your advice?Synthetic oil story. I used to manage a truck leasing company. We used RPM Delo in all of the Cummins and Detroit diesels. One customer asked about Mobil 1 when it came out. We told him not to worry about it. Oil and engine maintenance were part of his lease.
A few weeks later he came into my office and told me his story. He decided we were full of it and he changed the oil in one of their trucks and used Mobil 1. At five bucks a quart in 1973 dollars. On the way back to Dallas from Houston an oil line busted and dumped something like 14 gallons on the highway.
We never heard him talk about synthetics again.
