What is a good Synthetic oil to run in my Splitters engine?
I do have a small weep/crack in the bottom of case.
Thanks
Sean
Thanks
Sean
I run Amsoil in everything I own and the fleet I manage as well, except during break in. The only exception is the 2 cycle oil I mix into the diesel for my truck. That gets Walmarts cheapest TC-W3.
You don't have too but it helps lube the pump and engine internals . This modern day low sulpher diesel is crap.2 cycle diesel? That you have to add oil to? Never heard of such a thing....
I run canola in all my diesels.
OP- My experience with synthetics is if you have a leak now it will become worse when you switch to synthetic. I've tried synthetics in a few pieces of equipment I own and was not impressed with results.
So before I switch to Synthetic, should I add some mystery oil, and then change it after it's run hot?
I run Rotella T6 5W-40 in just about all my OPE anymore. You can get a gallon jug at Wally World for $20.
-25 and I have to worry more about the operator functioning than the equipment.
I used to do that as well but I've found that it's too thick for winter use. It was bad enough in my garden tractor that the govener wouldn't work and it would rev the engine to the moon till the oil warmed up a bit. Exactly what I wanted... that 20hp Briggs spinnign to 10 grand at -25*
For small engines I generally don't get fussy. Oil level is ok and not 15 years old, good enough for me.![]()
