This is a no brainer I realize - in terms of my lack thereof anyway. I have been tuning my EKO 60, and for the last week or so, it has been "cooking with gas" as they say. Really nice blue flame, and lots of heat. Today, with the snowstorm we got in the NE, I have barely been able to get the thing to run, much less put out great heat. Dull is about the only word to describe its performance. If I hadn't had the chimney apart last week and found it perfectly clean, I would suspect a blockage. Then it dawned on me the wind was coming in from the NE, over the top of the ridge of the house, so that my wife was complaining of smoke smell. Normally all I get is water vapor out the chimney. In warmer weather, and once in a while on other occasions, I have had the same lazy fire problem. So it finally dawned on me the chimney must be the source of these off and on problems. The 8" metalbestos chimney runs through the house, but extends only about 5' above the roof. It is on the western side of the building, only about 1/3 of the way up the roof. With the normal westerly winds, it is fine, but with the wind shift tonight, it just won't burn, despite a beautiful deep bed of coals. I can barely get a fire out of the nozzles. I know the chimney is supposed to be 10' from the roof on a horizontal - I'll guess mine is only about 6', as that was as much pipe as I had, and I figured it should be good enough. Tomorrow I will find someone who sells the pipe and add another 3' on, and my guess is it will solve these intermittent weak fire issues, that I used to attribute to the boiler and the various settings. I guess this is just a reminder of how important the correct chimney design can be to a wood burner.
