Glad that worked for you, MontanaSam. I've had mixed but also encouraging results so far after bending the tab back enough so that the primary inlet has just a sliver left.
So here's what I'm noticing: great air control now when turned down low. Secondaries are nice and mellow and less heat is going up the pipe. Also, very clean secondaries--all blue flames above the wood while wood below is simply dark and charred with a little glowing embers. No orange primary flames, even with pine. Also, the secondaries seem to be lasting a LOT longer.I just made a small fire using one large split of pine that I cut into different sized pieces of kindling and a couple 3" pieces. it's been firing off secondaries for well over an hour now. Also, stove cruises at a much lower temperature. Never exceeds 530-540F in the center spot above door. This is all pretty exciting because it could mean I'll use a lot less wood this winter... if I can just figure one thing out:
The problem is after a few hours or however long it takes, the secondaries go out. and when they go out, the stove starts smoking heavily, indicating that the wood has not completed the secondary combustion. Before the primary air modification, this was never a problem for my stove; once it got going, it cruised until everything was clean charcoal and, I never saw a trace of smoke, except perhaps with really lousy wood. This isn't a huge problem, but it does mean for overnight burns, I need to leave the primary open enough to sustain a complete secondary burn. I guess I'll just have to play with it.
So what I'm finding out is that PE obviously put a lot of thought into where they made that primary air control stop. They knew that a certain amount of primary air would be necessary to sustain a complete secondary burn for the widest range of setups.
I'm not totally ready to blame the stove, as this could be a fuel issue. Next time I'm home all day, I'll pull out my dryest, hardest woods and make sure I'm using the primo fuel and monitor the stove the whole day to see what happens.
