My house has a kiva-style fireplace. It's full masonry and a massive beast, but has an unusual opening size and shape. It looks like all the inserts I see are designed for larger, square openings.
It has gas to it and currently is burning some gas logs that look great IMO. The ambiance of the fireplace as it is can't be beat and is the focal point of my house. I heat my house and run the fireplace using propane. Obviously the fireplace is mainly used as decoration now and isn't much of a heater.
As everyone probably knows propane has gotten out of control, plus I'm on 20 wooded acres with a good amount of fallen trees so naturally thoughts turn to the possibility of supplementing my heat with wood. But with several weeks of off and on googling I have not found a stove or insert that would work well and look good with this fireplace, so i wondered if there were any suggestions here.
Here's the fireplace:
The dimensions of the firebox opening are:
32" wide
22" deep (the firebrick part, including the masonry/stucco front it's 27" deep)
30" tall to the top of the rounded part (this seems short when looking at insert specs online). The straight sides are 18" tall before the curving starts. However behind the curved opening the firebox is square.
Gas and outside air inlet on the back left when looking at it.
Construction is all masonry (cinderblock/firebrick/chimney tile) except for the hearth which is a wooden box with the the tile on top and stucco applied to match.
The area to be heated is about 1500 sf... 1000 sf first floor plus 500 sf loft.
At this point it's just window shopping/fantasy but you never know if the right solution presents itself. Suggestions welcome!
![Suitable stove/insert for a Kiva-style fireplace? Suitable stove/insert for a Kiva-style fireplace?](/talk/proxy.php?image=http%3A%2F%2Fi189.photobucket.com%2Falbums%2Fz267%2Ftherealmjfox%2Fphoto5.jpg&hash=82522d78a682ba2132bd63896d732748)
32" wide
