willworkforwood said:The temps that you posted are not what we usually see for hydronic boilers, but OTOH, I don't know anything about your boiler, aside from what's on their site. From what you wrote, it sounds like the pump driving your load(s) comes on at a low temp - maybe 50*C ? So, I''m wondering, by circulating fairly cool water through the boiler, if perhaps it's struggling for a long time to get a good fire going (due to poor combustion environment), and actually never really does get to optimal output. Being able to almost touch the flue would tend to support the idea that the fire is weak. If what I said is correct, is it possible to keep the load pump off until the boiler has a good, hot fire going? (initially just to test the theory) Again, I don't really know anything about your system - sounds like it might be unpressurized, and maybe operates differently. But, based on your boiler's firebox size, the quality of wood you're using, and your outdoor temps, it just seems like your existing boiler should be doing better than what you're reporting. Also, how about your chimney - any big amount of soot or creosote? Just some ideas, but I could also be barking up the wrong red box.
Be interested to hear what the expected normal temps are in a boiler like this with an open system.
When we have the pump thermostat set to say 70 degC then the pump cycles so much that the radiators are ineffective. Often toyed with putting something like the Danfoss on it but could not get any advise from the boiler maker what return temps should be.
