Perfect thanks. Was just looking it up here;Typically the first number is the diameter (size of hole you need) and the second number is the "grip" or maximum thickness of material it can join.
For a chimney liner I would probably go with a 1/8" (~4 mm) diameter and grip of 1/8 or 1/4" (4-8 mm). I suppose it doesn't matter too much if you go a little bigger, but you may need a beefier tool.
I misspoke, you will need a hole slightly larger than the rivet diameter. The page you found is good.
That's great that you have a plan to insulate the liner. You will enjoy the performance boost from insulation.
Wrapping rockwool around a pipe can be tricky because it likes to tear and crumble, at least that's my experience with the stuff we have here. I'm sure you'll figure out good technique.
A wire wrap / mesh is a good idea to keep it from catching on the bricks as it goes up. Do you have foil tape available? That would be another option. I wouldn't use duct tape just because you can't guarantee it wouldn't melt.
Ok great that will be easier. That stuff may still be hard to wrap though because it's so thick. For reference, chimney liner blankets here are typically about 1/2" to at most 1" (1 - 2 cm) thickness. So in a way that stuff would be overkill. However it won't hurt as long as you can wrap it.
Now we're talking! This will work well. If you can find a foil faced version, even better.Just found they have ceramic wraps also. 25mm and 50mm.
Not sure how fragile this is though. No layer covering. Would this tear easily?
Manta De Fibra Cerámica Espesor 12 Mm Por Mt 2 - $ 793,8
MAXIMA CALIDAD: Densidad 128kg/m3*ATENCION: El precio publicado es por 1 m2 ****ROLLOS DE 14.64 Mts X 0.61 Mts X 13 mm****También tenemos en ESPESORES de 25 y 50 mm (ver publicaciones) MANTA FIBRA CERÁMICA .... TAMBIEN TENEMOS en TELA , COPOS y CARTON !!!Manta de fibra cerámica con muy baja...articulo.mercadolibre.com.uy
As a self reporting spoiled American who is just used to being able to buy anything I want online I found this thread very refreshing and educational. Making something work with what you have access to is an important skill lots of us don't have anymore. I am trying to traxj this to my kids...who knows if they are listening lol.. Great project and I enjoyed following the progress. I hope it works out well!
I think the ceramic fiber will be easier to work with than the rockwool. It can still tear if you try to stretch or fold it though.So a much better option? Worth the extra $$$?
I could always buy several rolls of tape and wrap them myself.
I have a 13cm liner so not too wide.
Normally the insulation would get encased in a stainless steel mesh sleeve that protects it and keeps it intact.The seller just informed me he has the ceramic cloth to cover the fibre, 1/16.
But that gets too pricey. 1174 pesos per metre!!
Fibra Cerámica Tela-manta 1/16 1 Mts. - $ 1.314,18
****** ATENCION: El precio publicado es por 1 m ***** TAMBIEN TENEMOS en CORDONES, MANTAS CARTON Y COPOS !! ****** TENEMOS TAMBIEN EN ESPESOR 1/8" (ver publicacion) *** ROLLOS DE 30 MT X 1 ***APLICACIONES:REVESTIMIENTOSCORTA FUEGOSHORNOS CONTINUOS E INTERMITENTESCALDERASHORNOS PLANTA DE...articulo.mercadolibre.com.uy
