I'm contemplating doing this job myself.
We're having a new log burning stove inserted into our old open fireplace here in Uruguay.
The liners are all 1 meter rigid tube types 100cm. The height of my flue is about 6meters.
Now the large concrete top is shared with the neighbor.
I thought about 2 options.
1) grind a hole (150-160mm) in the top above my flue to insert the liner and top it off with a plate and hat.
2) Cut the concrete top down the middle, remove it, and fix the top plate directly on the sides of the chimney walls sealing it better. I'll have better access for cleaning in the future if removed.
What do people suggest?
This guy had a neat trick to lower the tubes. But I think there is enough space in my large fireplace to feed them up vertically.
Thanks!
![Suggestions needed to feed a rigid tube liner above the roof with a flat concrete top. Suggestions needed to feed a rigid tube liner above the roof with a flat concrete top.](https://www.hearth.com/talk/data/attachments/275/275824-cc0d2f2ac12838cac885b00bcde02f74.jpg)
Thanks!
![Suggestions needed to feed a rigid tube liner above the roof with a flat concrete top. Suggestions needed to feed a rigid tube liner above the roof with a flat concrete top.](https://www.hearth.com/talk/data/attachments/275/275823-cd6273e23632148c00d0fea622e4a5b1.jpg)
