I really appreciate the response! I added a few pictures of where the cabin designer put the woodstove thimble. My wife is really hoping we can use a woodstove. Any idea if this is enough room?Any caulk or silicone can fix the cracks. You may need to use a backer on some of the wider gaps. Some sealants can not be painted afterwords, so you may want to be careful with the choice.
The hardest part of heating small areas is achieving an even heat. Once you heat the space up, a wood stove doesn’t shut off. It has to continue pumping out heat until all of the fuel is used.
The 2nd hardest part of heating small spaces is the loss of floor space. Wood stoves need open space between the stove and combustible materials like walls. With so little floor space available, setting aside the square footage for the stove might not be acceptable.
For these reasons, I’d look into wall mounted vented propane or electric heat.
We want to eventually be able to sleep in it. This is not meant to be a primary residence, just a spot to sleep for a day or two here and there. Just wondering if it is possible/smart to have a woodstove in it with insulating it.What is the purpose of this building? Do you plan to camp in it?
We would like to be able to sleep in it in winter at some point. We have from now until the next winter to make it appropriate for winter sleeping.Are you planning on using this 3 seasons. It can work. Thats how many summer cabins are built if there is no winter heat. The wood drys out. If it's winter use I would insulate under the siding with the best R value foam. Next I would insulate interior ceiling. Although the space is small, being open will allow more even heating. It's always hard to say how much stove is needed to heat a house, no insulation will definitely make it as hard as it gets
Appreciate the info! So, do you reckon we could get away without insulating the ceiling?The ribbed tin roof with act like a heat sink and will actually transfer your heat into the outside air pretty efficiently.
Also a tiny stove won’t burn for very long so you will be waking up to a un heated space. It will be pretty difficult to maintain the “cozy cabin” feel.
I’ve lived on a boat with a micro wood stove in winter and you never are warm like in a house
If it were me I would get some good sleeping bags
We definitely plan on using sleeping bags, but we aren't sure what is essential and what we can get away with regarding insulating.But then why not camp in a tent?
I would not. With a small stove and some (not perfect) insulation you may still need your sleeping bags to stay warm at the end of the night. (And a big stove with sufficient burn time to avoid that would be too large physically..)
If you seal it and insulate it well, you could sleep comfortably in whatever you wish using just a modest stove.We definitely plan on using sleeping bags, but we aren't sure what is essential and what we can get away with regarding insulating.
A winter without insulation will quickly tell you what you want to /need to change!We definitely plan on using sleeping bags, but we aren't sure what is essential and what we can get away with regarding insulating.
