E
elkimmeg
Guest
Basically I loaded m main floor stove at a little before 7:00 this morning, Raked up a good amount of glowing coals in a pile and added some smaller splits first, then the bigger ones. Down stairs temp was still 69 degrees outside 23 degrees. When I returned home around 4:00 ,the interior temp was still 69 and enough coals to repeat the morning’s process. Temp at the time I arrived was 37 now 23 outside, inside has climbed to 73 Cat engaged and running about 550 degrees griddle top.
My family room was 64 and I decided to fire the other stove in there about 4:30
Right now 71 cat engaged running 500 degrees griddle top.
Tonight is a good test, windy and temps may make the low teens. Will the cat stoves deliver the goods?
