kyas said:
			What do they mean about this sentence.  Page 10.  Subsequent Cold Starts: In a cold start situation, the unit should be operated at a “5” setting
until the room air blower begins to operate.  Basically this is what I have been trying to follow.  I will shut the stove down to do a cleaning.  Once I'm done I will hit the on button and hit both buttons to read 5 and once the room air blower begins I turn the buttons down to either 1-1 or 2-2.  So is this wrong?  I see what you are saying about the unit being preset and all, but it seems to be Contradicting.  So correct me if I am wrong.  I should leave my settings on 1-1 or 2-2 when I start it back up after it being shut down and cold?
I'm hoping Mike H. from Englander might catch this thread. I always try to put 'Englander' in the title to catch his eye. Anyway, to answer your question, "I should leave my settings on 1-1 or 2-2 when I start it back up after it being shut down and cold?", that is exactly what I've been doing all winter, and have had no start-up problems.
All I can think of here is that manually changing the settings to 5 5, per the manual instruction, isn't wrong, it's just not necessary since the start-up cycle is already preset to 5 5, which gets 'triggered' when you press 'on'. I don't know for sure, but from my experience, this gets cancelled if you change one or both of the settings after pressing 'on' (unless the changes are to 5 5 or above).
To explain the premature shut down you described in your initial post, here is what I think is happening. Pressing 'on' and immediately, or during the start-up cycle, changing fuel and blower to 1 1 or 2 2, without subsequently pressing 'on' again, seems to cancel the pre-set 5 5 setting of the start-up cycle. At 1 1 or 2 2, there isn't enough fuel fed to the burnpot to allow start-up, so it shuts down.
If you leave the settings alone, from the previous burn, and press 'on' to initiate startup, it should go into 5 5 for the 20 minutes of startup cycle, automatically, no need to change the settings to 5 5. This doesn't appear in the LED windows, but the feed rate and fan level during the startup cycle would seem to be at the 5 5 setting. It could be that the older control board didn't have this pre-set feature, and the user had to manually set up a cold start to 5 5 to allow enough fuel and air to guarantee successful startup.
So, IMO, forget the manual's instruction to set the fuel/fan to 5 5. Just let it go through it's cycle and if you want to change the settings for after the startup, either do it right away after pressing 'on', then press 'on' again, or wait until the S U lights go out to change them.
