Agreed. I was making the assumption that we are talking about the atypical over drafting install.
I agree that adding a damper is essentially modifying the stove too.
However, a damper in the pipe is still widely accepted as normal by most stove users. In fact, a very common question that we get from prospective buyers is "do I need a damper in the pipe".
On the other hand, no one has ever asked if they will need to add some foil tape to their new stove.
The damper is familiar to most, while asking a user to slap foil tape on an intake seems a bit like saying that we made the stove wrong.
Jason
Restricting air flow, weather on the intake or exhaust side is essentially accomplishing the same goal. Correcting an overdraft issue. Not sure how telling customers to do it on the exhaust side would be correct but on the intake would be some sort of admission that the stove is flawed.
There will be overdraft issues in the real world and just my opinion, if it can be corrected with something as cheap and easy as a magnet, that's a better choice than a pipe damper but I must admit I just don't like using a pipe damper.
I wonder what the down side would be to having adjustable secondary air, without the consumer having the ability to close it off more than X%.
It boils down to perception of the stove owner. For the discerning folks who frequent this forum, hearing a manufacturer say to block off an air opening in the stove makes sense. However, to a new stove owner, who has less understanding of the way the air intake affects the stove, it will just sound like redneck engineering.
Three letters: E... P... A.
If in any more than a handful of cases a customer needs to install a damper or tape off an air supply, those cases also being instances where the stove is installed and vented according to the manufacturers specs, then in my opinion, a stove is made wrong.
Consider also the other variable in the stove/flue system that affects draft: the weather. So you are not dealing with a fixed/closed system. The variation in outdoor temps, winds and atmospheric pressure is not something that could easily be accounted for in an owner's manual giving directions on how to adjust the secondary air input.
I think the only good answer is a smart stove, that has the ability to constantly adjust air flow by having real-time inputs (stove temp, flue temp, draft measurement, etc.) at every stage of the burn cycle.
But aluminum foil and magnets will always be cheaper.
Yay! Enjoy!well i've got my magnets ready if needed. stove is getting picked up tomororow and installed![]()
No luck as yet BeGreen. I have just started a convo with my lovely new dealers .. So I'll explore the cap idea too with them. They want to check out the 'Pascal something or other' on the flue first.. I'm intrigued.. Some way of measuring the updraft apparently?Did you ask around about a wind blocking cap? Any luck?
Correct me if I'm wrong ... but I think the main problem with barometric dampers is how they introduce cool room air into the chimney system, which could force gasses to condense into creosote that otherwise might not have without the baro damper. It's not such a problem for gas/oil/hard coal/etc. whose flue gas condensates aren't as flammable I think.So what's the difference between the flue dampers that some woodstoves have and barometric dampers? Don't the latter have some sort of automatic action that is dictated by the weather, atmospheric conditions, etc? If that's the case why can't woodstoves utilise them too?
I had never thought of aluminium foil.... Gee whiz - and I went and spent £15 on bits of steel, nUts and bolts...
For me at the moment, the appeal of a damper against a secondary intake mod is the relative ease - as things stand, when the wind gets up, I am crawling into an awkward space behind a 600deg stove and reaching into a tiny gap between the rear of the stove and the rear heat sheild to fix a little pice of metal into a hard to reach impossible to see hole. Flicking a damper this way or that, depending on how strong the wind is from hour to hour starts to look appealing...
The EPA should stuff wool in their intake!
Just teasing, I love those guys
