I have a Jotul Castine 400. The little rod for adjusting the bottom vent is quite stuck in the closed position. I don't want to force it. How can I get it free?
Thanks for your help.
I inherited that stove when I moved to my current house. I've sold it since. But I had the same problem. I ended up having to bend the rod a little bit and grind the sliding plate down a little bit till it moved fairly freely. Still had a little tension at times but was much better doing that. Took a little tinkering at the vise and the grinding wheel but I eventually got it pretty good.
