He will shoot movies on demand if you ask nicelyHi Mike-
Thanks for the response. I have seen your videos. Very informative. That's how I got started considering a Wood Gun!
Scott
Do you have any requests?He will shoot movies on demand if you ask nicely
I am not saying anything against the woodgun it obviously does the job and does it well most of the time but what other options have you considerd? In my opinion I do not see the woodgun as the first option UNLESS you are planning on not using storage or idling more than one should. I am just going byt the 2 different wood boilers that I have used, the many I have looked at and researched, and the plethera of info on this site.
Edit: Let me add I do not think it is nesasarily a bad option...
I'm a one-year Woodgunner and couldn't be happier. It takes a few weeks to figure out how these things like to work and the little tricks that make them work well for your application, but once you get through that the rest it gravy. Anyone who owns one will tell you there's a learning curve that can be frustrating. Once you've got it figured out, you'll love it. I empty my ash pan twice a week, rake the lower tubes out once every two or three weeks and fill it with wood twice a day. That's it. It just runs and does what its built to do with no fanfare, no fuss, no whistles and bells. Its a simple old-school machine.
I really can't understand why anyone would bother with storage. Yes it may burn more efficiently, a little less wood but for me not having to relight a fire all the time is a big advantage, I light my boiler once over the whole winter. and I heat 4000SF with 8 cord of maple which cost me $880.00. I load the boiler 2 or 3 times per day.
somebody who wanted to heat DHW through the summer with wood. i wouldnt want a WG cranking all summer to get DHW, especially in a basement when you are typically trying to cool the house.
i agree the WG claim to fame is the ability to operate almost as efficiently when cycling vs. running full out. if you are planing on installing storage anyway, then you open up many more boiler options for yourself. if storage is not an option for your particular setup, then i believe WG is a VERY strong contender for the boiler of choice.
I heat all my domestic all year round with the woodgun, i the summer I light a fire with 3 or 4 spruce rounds ( I have 25 acres of spruce outside my door for free) at 6am and then go to work, my wife switches the "start" over to "run" an hour or so later and that is it until the next morning, that produces enough hot water for the 4 of us until the next day and with the low temp shut down you don't have to think about it again. I stuffed fiberglass insulation under the boiler as well to help hold the heat in.
I just have the domestic coil option in the woodgun.
.....looking forward to hearing about it's success!Scott,
Back-puffing with the cycle timer is the only issue that isn't completely resolved in my opinion, and over the course of the summer I plan to design a very simple solution that will prevent that once and for all.
ac
So far, I am open to other boiler options. I have been reading threads on this forum since last summer, and my interest has pointed in one direction or another throughout that time. The Wood Gun is appealing to me for a few reasons:
- It is built out of stainless steel.
- I can use my existing 6" chimney.
- The firebox can accept (and work with) larger pieces of wood --- as I explained earlier in this thread.
- The boiler apparently works OK with a small amount of storage. I have limited space for that --- some, but not a lot.
- I like the simple off-the-shelf controls. Nothing becomes obsolete faster than electronics.
- In searching through this forum, I have not read about too many people having problems. Most owners seem to be happy, and are not grumbling about rust or creosote buildup, etc.
- AHS has been building Wood Guns for a long time, here in the US, in neighboring Pennsylvania.
- The WG runs pressurized, so it is easier to incorporate into my existing forced hot water heating plant.
I have looked at a lot of wood gasification boilers in the last several months, and will continue to look at more --- keeping my options open. But, so far, Wood Gun has more checks on the positive side of my ledger.
Thank you all for your help and input.
Scott
Mike-
You did hit on one point that I do not like about the Wood Gun, that being price. Boy they don't give those away, do they?
I looked at the BioMass boilers from New Horizon. Their data did not indicate whether or not they can deal with larger pieces of wood. The price is certainly attractive. Now, being a bio-mass boiler, have you burned stuff other than wood in yours? Their specs read "Corn Cobs with Kernels, 50% of Coal, Saw Dust, Wood Chips (50%), any kind of pellets". I don't read about too many people using anything but wood. Certainly, being able to heat my home with relatively easy to obtain waist items would be a plus.
Scott
