I'm hoping to get feedback on this (also hoping the technology cooperates in my first effort to post a graphic)(excuse my non-artist skills!)
since I am ending up going with non-pressurized storage, I want to make particular effort to have the inflows and outflows of the tank occur in a way that maximizes stratification, and does not mix the tank's contents all around.
below, depicted in my crude sketch, is the concept, which would be:
a round large diameter (6-8 inch?) hollow vertical column in the center of the tank, with a horizontal partition at its vertical midpoint, and one ring of holes around the perimeter near the bottom, and another ring of holes near the top, not too far below the water level. intake and suction pipes enter these upper and lower chambers.
"hot" intake and outlet pipe is on left, "cold" is on right
The idea/ hope is that by having the intake and suction pipes enter these larger chambers, velocity of flow will be greatly reduced where the flow "meets" the tank as a whole- to avoid "stirring up" the tank. Having the ring of holes at top/ bottom of the large diameter column will cause water to be pushed to or drawn from the places where the temperature differential is greatest. Horizontal partition in the middle of the vertical column will keep the intake and outflows from mixing Having this all in the middle seems like the place to have it, since the tank's sides, being naturally coolest (even with insulation) will have their own convection going on.
reactions, ideas, suggestions? fire away, please!
