If the substrate is CERAMIC. No thermal shock is encountered with dura foil stainless substrates.
this is true, but I didn't know what type of cat was in the stove in question so I figured it would be a good thing to bring up
Things to keep your eyes open is someone remodeling and tearing out trashed hardwood flooring..
Try calling NORTH IDAHO ENERGY LOGS in Moyie Springs Idaho. The owner tells me he has set up dealers in New York to sell their logs. They are super, just burn 2-3 at a time, mixed with some cordwood and you'll be happy.My stove is an Ashford 30.1 with the steel cat... I've been looking for bio bricks a little up here, have only found one place so far, selling them for $370/ ton. Gonna pass on that.. maybe I'll be burning some pallet wood this year.
Still well over 99% oak that small impurity should not change much. If no fumes in the firepit why worry about the stove? Unless a fussy cat stove that needs perfect wood. Do you need a firewood washing machine for a cat stove?I've been tearing out the old hardwood floors in my house lately... pretty sure I don't want to burn those with all their layers of poly and who knows what else over the years... a good amount of it was painted a few times as well. They've just been going to the outside fire pit.
Keep the door gasket snug, mimimize use of wood above 20%. If you are needing to keep the door ajar in order to get the wood to burn, either your wood is really wet or not enough draw and leaving a door ajar would be hard on the cat. Other than these fyi's, you should be fine.This concerns me. I am supplementing my wood with envi blocks and my wood splits a couple weeks ago ranged from 15-25%. I took wood from the outside stack of my cube of wood (only way to fit it) so I'm thinking the inside wood MC is higher (lets say 25-30%). BK I have a new BK King, it's looking like my cat is ceramic? I'm concerned about reloading and damaging the cat.
Going on year 4 with my Sedore and can attest to burning my share of less than seasoned wood. The Sedore being a top load, down draft design will handle poorly seasoned wood (psw) if it is placed at the top of the load - thus requiring some dry wood to build the coals and get the stove and pipe temps right. The psw drys out a bit as the stove only burns the wood at the bottom of the stack, so by the time stack has burned down and the psw reaches the coals - it is much drier and burns decent enough. You still have the problems of crud formation, but it is doable as long as you are committed to regular sweeps and cap cleanings. Like mentioned above - dry wood is always better.I've read that the Sedore downdraft stove is not too bad with partially seasoned wood. At least that's the claim.
Pallets are a SOB unless you have a good tool like thisI know people burn pallets in a bind but WOW those things are held together with a lot of nails. They are more work than cutting regular cord wood. I can't imagine cutting up enough of those things to make it through a Schenectady Winter .
We had a fella selling green wood here and encouraging people to buy it for their fire pits to slow down the fire...lolThe difference in burn is noticeable in outdoor fire pits too.
(broken image removed)
