Hi All,
Thanks to all the great advice on here i hired a better experienced company at giving a shot at installing my stove. To the direction given here they agreed in relocating my thimble higher up as opposed to using the rear vent option on my stove. Came out great and stove has been doing well. It vents into a brick chimney with a new liner. Chimney is short but meets hearthstones minimum requirement of 16 feet. This is the first time i have ever used a wood stove before so learning as i go and keep coming back here to look at older threads to get some tips but do have some questions i need further guidance on.
1. The Hearthstone Manchester has a row of vents on the top of the stove that allows heat to come out from convection. Since these holes are on top of the stove some of the heat goes straight up to the ceiling. I have the stove in my mud room and im trying to get as much heat to move forward as possible versus up as Im trying to get the heat to move across the first floor of our cape. Has anyone covered these holes up with a sheet of steel? Is that even worth it? There are also front vents as well on this stove. I added a pic of top vents as fyi.
2. Loading and reloading, I have only been using the stove for 2 days now so still experimenting and trying to figure it all out on what's best. At first i started a small fire and then threw a few medium to smaller splits on it and just kept adding wood through out the day as it burned down. At night i didn't load it as much as I see others load for the overnight burn but I got about 7 hours of loosely packed splits (loaded at 9:30 and by 4am it was just about down to coals, in the teens at night). Over the course of 2 days I had a ton of coals which was basically up to the dog house which is quite a few inches deep, I'm thinking because of the way i was loading and burning it. I always had the air intake closed off by about 90% when it was good and hot . Last night instead of loading I just let the coals burn down and tried to clear some of them and some ash this morning and start with a more packed load. Here's a pic 20 minutes after I loaded it and then an hour later. It seems to burns fast even closed off at 90%, do you guys pack the stove more than this? I can only really do e/w as n/s the stove is not deep enough compared to the split lengths I have. Should I pack it closer to the window and higher?
thanks all
![Stove vent and loading/reloading newbie?'s Stove vent and loading/reloading newbie?'s](https://www.hearth.com/talk/data/attachments/290/290727-8041f8301b6286aeb2b35b7fbc65a9fa.jpg)
thanks all
![Stove vent and loading/reloading newbie?'s Stove vent and loading/reloading newbie?'s](https://www.hearth.com/talk/data/attachments/290/290724-d879da80e7d4edde92993815b6fba031.jpg)
![Stove vent and loading/reloading newbie?'s Stove vent and loading/reloading newbie?'s](https://www.hearth.com/talk/data/attachments/290/290725-5608929780cc2f9f0fc66e8e605e267b.jpg)
![Stove vent and loading/reloading newbie?'s Stove vent and loading/reloading newbie?'s](https://www.hearth.com/talk/data/attachments/290/290726-3c0b674713712d978cc72e54fd2a504f.jpg)
