cooler than stove room without any fans. Far rooms stay closed often.Somehow I don't think the OP wanted examples of the extremes.
I don't think so. Soapstone is nice, but not magical. Heat is convecting, with help. It might be that remodeling insulation/sealing/new windows has improved heat retention and someone has discovered the fan blowing cool air toward the stove trick?
https://www.hearth.com/talk/threads/thru-wall-fans.110061/#post-1455081
What would be a good idea to move air from the upstairs? Our very back bedroom on the second floor is always a bit chilly - could I place a fan in that room or out in the hallway to try and draw the air or does it need to be on the same floor as the stove? I'm starting to see myself hanging string from the ceiling and figuring out where my air moves to.
You want to make sure that air gets back to stove room and your not just equalizing out the temperature on that floor. Fan at stairs, but I have read here few have had success with this. Also have heard about thru floor registers. Maybe that would work.?I'm thinking of putting a fan on the floor in the doorway to the back bedroom upstairs and see if it works. If nothing else it can't hurt to try and play with it to see where I can get the air to move to. I see strings in my future - my wife is going to hate you guys.
Well, it's certainly easier to move the cool air along the flat floor than to try to move warm air through doorways, the tops of which are lower than the ceiling....There must be something else to it...
LOL, He's probably moving stoves again. Or having a meltown?Where's BrowningBAR? He gets all flustered when it drops below 85F in his house, mid-January.
Yeah, but it's a dry heat.believe it or not I have gotten very close to 100 once![]()
The radiator is normally near or under the window. As with most heating ducts or baseboard is normally placed on the coldest or outside wall.
Keeping temps in your house even is all about getting a good convection loop running, Cold air back to the stove warm air away from the stove, You can do this with fans but it will work out bet if you can encourage a loop to run naturally. In my house I can turn on the celing fan in the Master bedroom, furthest room from stove, for 30min to get things started on a reload and then I leave shut the fan off and the natural currents just keep going.
This is a great example of how to do it, you need to cool the air furthest from the stove. it will naturally fall to the floor and be replaced with warmer air from the ceiling coming from the stove. The cold air will then move along the floor to replace the warm air rising near the stove. Here is a pic for a radiator in a single room, now just expand this concept to the whole house and there you are.
