Stove Reccomemdations
MTWoodBurner
9
Troy, MT
I’ve lurked here off and on for years but never had the need to post before now so thanks to everyone for all of the info I have gathered over the years.
I need/want to replace a PE Standard built in the early 90’s that appears to have been over fired a few times.
26x32 slab footprint with an open garage and restroom downstairs where the wood stove is located. Ceiling height is 10’
Floor between is uninsulated, and above is a bedroom, kitchen/living room and a bedroom with a closet, Bedroom has a loft above so 2nd floor ceiling is vaulted except for the bedroom/bathroom.
Money is alway an object but can afford whatever I need, but I work hard for my money so savings are a plus.
I have an 8” flue, 24-26ish feet from top of the stove to the cap.
I would really like long burn times (10 hrs or longer when needed) and a large firebox. My current stove is 2cf and I find it too small to get much inside if there is a good bed of coals without breaking them up good, otherwise I hit the top when loading.
I don’t care if it catalytic or non catalytic, what I want is a good stove that will do the job and if that means maintenance of the catalyst every few years then so be it.
I do have a heat pump that I run along with burning wood 24/7 but when I need heat the most (below zero) it will be of no use so this stove in the most important time will be my primary source.
I am in far NW Montana and burn red fir/ larch.
Any and all help is appreciated.
Blaze King ....King
Large stove, deep belly, and 8'' flue. Pretty much what you asked for.
Con: not cheap. Then again....no new stove is cheap, especially with an 8'' flue collar.
I have a BK in my basement with 1.5 floors above that. 27 ft plus a longish horizontal run of 4 ft.
Works like a charm, heating all my home to 70 at least down to 0 F with 10 hr burns at that temp for the 2.9 cu ft firebox.
70s home with mediocre wall insulation but excellent air sealing and R57 in the attics. 1700 sq ft plus 825 in the basement.
Warmer climate though.
If you have an 8" ID chimney pipe (or 8" *insulated* liner in masonry), I second the BK King.
If it's 8" OD (so 6" ID) chimney pipe, get a Princess or 30.2 model.
There are good tube stoves too, e.g. PE Alderlea T6 that'll give more heat (and shorter burn times) at their max output but won't be able to do 20+ hrs on a load in shoulder season when you need less heat. That might work as well given that shoulder season is perfect for heat pumps.
Reactions: all night moe
If the 8” is in good shape. A BK king would be my choice. Lining for a 6” stove probably makes something like a big Drolet on par with a BK king but I would price it out.
BK is what I felt I needed, I was leaning toward the Princess 32 for strictly costs va the King reasons but didn’t know how big of a deal it was to have the 8” flue on it.
The other that I had considered was the Buck 91 but the BK seems to be a legend in the wood heat world. I didn’t mention these before because I wanted opinions based on your thoughts and not mine which I got.
Why is the BTU rating literally half on the BK stoves (and the Buck) and yet they are so much better for large areas? I know there is some trickery in this that I don’t understand but would like to.
Their design has expanded the output range at the bottom,.but they still can go full bore.
Numbers given depend on the way it was tested, and there are a lot of variables there that may end up not reflecting normal usage. (Testing ending at 80% of load gone and averaging the BTU over those hours, vs +100% gone which takes many more hours etc.)
Folks here can burn down a 2.9 cubic ft firebox of oak in 7 hrs or so. (Or 30 hrs...!). That can be 50-60 lbs of oak. That's a number of BTUs in there that are released over 7 hrs, decreased by a 75% efficiency or so.
Do the math, get your BTUs based on user data rather than testing data.
Max BTU output from mfgs is often not reliable and surely not representative of what it would do every hour of the burn time (i.e. that rate might be reached only 1 hrs of the burn time).
For fir all this would be a bit lower BTUs (loaded), but still appreciable.
(edit: for FIR - rather than oak. d*mn autocorrect on my phone)
The thing most BK users will say is that not going in cycles (hot, slow cool down, repeat) means that the high output is rarely needed; the constant lower output meets the total BTU needs of the home and a higher pulse and glide is not needed. In fact comfort increases when having a constant temperature...
Your very welcome.
Keep us updated. It's great to hear results. ;)
Ok guys, please refrain from making fun of me lol.
I installed the princess and discovered that my flue is 8” and not 6”. Because it was necked down from 8” double wall to 6” single wall I never measured and just assumed (you don’t have to say it, I already know).
I’ve got 24’ or 8” (8’ of double and 16’ of triple). First fire I had an issue getting a good draft started, after a small load and 6 hours I refilled and am down for the night.
My question is how big of an issue will the 8” be for me? I’d prefer to not spend the money at this time but if it’s a must then so be it.
The season is close to an end. run what you got, being mindful of startup draft issues. Also may effect you if burning low and slow.
Plan on upgrading your stove pipe and chimney in the fall.
At least you do have a 6'' system. More compatible with many stoves, should you ever change out the princess.
Reactions: MTWoodBurner
Is startup the only time I would experience an issue? Typically we would fire up in early November and burn til mid March/early April.
The house is 2 years old so I’d be removing all “new” pipe to replace with new pipe.
Is there any damage to your stove that you been over firing?
slow startup and 8” may not be related. I would be concerned about over draft once it’s up to temp. A damper could likely be installed if you thought that was an issue. When it’s time to reload on a warm bed of coals open the bypass and observe how much ash flies around the box as you open the door. You BK thermostat is likely compensating for any over draft. If you can’t go a low as you would like too that might be a sign of too much draft.
Reactions: stoveliker
I was under the impression that smaller pipe drafted better (draft speed vs overall volume was my thinking).
Either way I guess I’ll just change it out as recommended after this burn season.
8” flows more. The consequence is it is slower given the flue gasses more time to cool down. If you run it the rest of the season and it’s a clean chimney and you have all the control over the fire you want I don’t see any evidence that you have to change it out. My guess is that the top will get kinda gunky if you run much on low.
Time will tell. Use evidence to make decisions. If it’s an old 8” that’s not it great shape that may push you to change it out. If it looks in good condition too to bottom and it’s clean I’d try it another year.
If you cat gets clogged it may be over drafting. Be careful not to let much ash get in the cat when cleaning the ash out.
In my experience, if a stove ran well on a 6" chimney, it normally would run fine on an 8" flue. I understand that BK has a lower low end, so the 6 to 8 difference could affect it on the extreme low end. I'm thinking too that the upper section of chimney area may have a bit more buildup of crud, but you'll know that when you clean at the end of the season. Enjoy your new stove, I bet its gonna do great. Stay warm, still freezing here in SE CT. We dodged a big storm, it stayed south, the VA/Carolinas are catching heck...
I was thinking with the 6'' BK, running thermostat on low in shoulder seasons, there may be some back drafting due to trying to keep the 8'' single wall warm enough?
chit, that’s good. What kinda wood are you burning ??
I have gotten 20 hrs on 2.9 cu ft of pine... 36 hrs on red oak.
It's not the wood species that matters, it's the thermostatic control avoiding heat spikes when things rearrange (fall/collapse) in the stove, and the cat allowing for very low smouldering while the chimney remains clean. Of course it's at a low output, so depending on your home you might be cold running 20+ hr cycles...
Larch and fir.
Update though, while I did clean the flue when I swapped stoves, I didn’t climb on the roof and check the cap so a couple days ago what was coming out of the cap didn’t look like a natural patter (no other way I could think today this) so I climbed up on a snowy 8/12 pitch roof (not fun) and the cap was nearly 💯 clogged. Took the cap off and zero backdraft into the house now.
Burned 1 - 1/4 split with a little kindling on bottom and 6 hrs later loaded it for the night. Only took 10-12 minutes from cold startup to active zone and working good.
Thanks again for all the patience, help and answers to my novice questions.
Good to hear this. There have been a lot of clogged cap screens this year. Enjoy the new stove.
