I’ve lurked here off and on for years but never had the need to post before now so thanks to everyone for all of the info I have gathered over the years.
I need/want to replace a PE Standard built in the early 90’s that appears to have been over fired a few times.
26x32 slab footprint with an open garage and restroom downstairs where the wood stove is located. Ceiling height is 10’
Floor between is uninsulated, and above is a bedroom, kitchen/living room and a bedroom with a closet, Bedroom has a loft above so 2nd floor ceiling is vaulted except for the bedroom/bathroom.
Money is alway an object but can afford whatever I need, but I work hard for my money so savings are a plus.
I have an 8” flue, 24-26ish feet from top of the stove to the cap.
I would really like long burn times (10 hrs or longer when needed) and a large firebox. My current stove is 2cf and I find it too small to get much inside if there is a good bed of coals without breaking them up good, otherwise I hit the top when loading.
I don’t care if it catalytic or non catalytic, what I want is a good stove that will do the job and if that means maintenance of the catalyst every few years then so be it.
I do have a heat pump that I run along with burning wood 24/7 but when I need heat the most (below zero) it will be of no use so this stove in the most important time will be my primary source.
I am in far NW Montana and burn red fir/ larch.
Any and all help is appreciated.
