I have a Duravent class A chimney. Would a universal/other brand flue extension work with my excel stove pipe?
Thanks
Thanks
KeithO said:I screwed up, the reply to this posting got posted in the wrong thread (could one of the administrators move it ?) Here is a set of my pictures with off the shelf parts:
https://www.hearth.com/econtent/index.php/forums/viewthread/9959/
JohnnyBravo said:i just finished my install. what i did was cut the outer pipe 1.5" shorter than the inner. then i recrimped the stainless so it would fit into the the stove properly. now i can screw to the inner liner. it was the only way i could see to get my pipe running the correct way and mate properly with the ceiling support.
KeithO said:Gooserider, I reposted the pictures in the posts that you moved. Thanks
Of course I'm not really going to leave the seam facing forward or the labels on, but it does help understand what the manufacturers intended. The only thing I'm personally not familar with is how to seal the joints of the double wall pipe ? The connections seem a lot looser than on stovepipe I have dealt with in the past, so I think it would be even more important to seal the joints, but one really can't see what one is doing...
How does one approach this ? A smear of stove cement on the inside of the female end of each inner pipe prior to assembly ?
hearthtools said:I see no reason to seal any kind of joints on wood stove pipe (as long as you dont have a gaping hole in the pipe Joint)
Just a good mechanical fasting (3 screws or rivits) so it dont come apart.
You have have a 1/2 hole in the side of your pipe if you have good draft smoke will not come out.
air will suck into the leaks and out stack.
BrotherBart said:hearthtools said:I see no reason to seal any kind of joints on wood stove pipe (as long as you dont have a gaping hole in the pipe Joint)
I have to disagree on that one Rod. Besides air leaks reducing overall draft, every pipe leak I have ever had has accumulated layers of creosote right at the leak due to the colder air cooling the gases passing by the leak when they get hit by the air.
BrotherBart said:Part of the father-in-law job description is to argue with the son-in-law.
hearthtools said:JohnnyBravo said:i just finished my install. what i did was cut the outer pipe 1.5" shorter than the inner. then i recrimped the stainless so it would fit into the the stove properly. now i can screw to the inner liner. it was the only way i could see to get my pipe running the correct way and mate properly with the ceiling support.
how did you connect your double wall pipe to the support box?
did you have a flue extension sticking out of the box?
Gooserider said:Great, glad you made it work for the photos, but how did you get the stove to draft sideways like that?![]()
Gooserider
BrotherBart said:Gooserider said:Great, glad you made it work for the photos, but how did you get the stove to draft sideways like that?![]()
Gooserider
OK. Time to define roles here.
Gooserider = Moderator
BroBart = Comedian
hearthtools said:BrotherBart said:Gooserider said:Great, glad you made it work for the photos, but how did you get the stove to draft sideways like that?![]()
Gooserider
BroBart = Comedian
you know there are 100's of comedians out of work you you guys are trying to make jokes?
