jmwe29 said:
Wow. Such wonderful people here! Andy is bound and determined to take the thing to someone, but I will at least work on the cleaning myself. Pellets are a whole new world to me and I had no clue these things are so incredibly complicated. Certainly not an old wood circulator! So someone will have to tell me where to start with a cleaning beyond the shop vac pulling out the ash in the burn pot. What next??
Once cleaned, I have a notion that I'll be calling US Stoves back again- after walking Andy thru all kinds of push-this-button gymnastics, the auger just completely quit and hasn't worked at all since, where it was just simply slow when we first got the thing. Betting the cleaning would have done it at that point, but now it's an electronic mess. My opinion of this company is deteriorating!
The following is done with the stove off, cold, and unplugged (never service the stove with it plugged in, there is always 120 volt ac in the stove as long as it is plugged in).
If you have a leaf blower that can be used as a leaf vacuum, apply that to the end of the venting be certain it isn't pointed at anything that you don't want covered in ash and turn it on and let it run until the air coming out is perfectly clear. While it is running and if the firebox walls are steel tap on them with a rubber mallet or use a hammer against a small block of wood on the walls, do not do the tapping routine on cast iron as it will crack and destroy cast.
Then making certain that you have a replacement combustion blower gasket remove and clean the combustion (exhaust) blower's impeller and any remaining stuff between the impeller and the motor mount plate. Clean the blower motor (and any cooling fan it has) Reinstall the blower back to its cavity.
I'd locate the hose going to the vacuum switch remove tube at both ends blow through the tube, then at the barb where the non switch end of the tubing was removed from I'd run a pipe cleaner or paper clip through, these have been known to plug up preventing the auger from turning.
Reinstall the vacuum hose.
Next I'd check the coupling between the auger motor and the auger frequently the set screw there can loosen up and the motor actually run but the auger not always turn. Then remove the pellets from the hopper and the auger flight cover (this is the part in the hooper that covers the auger (that is if this is a drop (top) feed device (I haven't bothered to download yet another USSC manual so I don't know what kind of feeder your stove has on it.) clean out all of the pellets and check for pellets lodged between the auger and the bottom of the flight (it is also possible for there to be a fines plug that prevents the auger from delivering pellets but not turning this will sometimes appear as a very slow feed). Put it back together.
While you are thoroughly up to your neck in a mess remove and clean the convection (room, distribution) blower including the motor and its cooling fan check the motor plate for lubrication information, obey that information, locate the lubrication ports (if any) and place 2 drops of the recommended oil into each port, spin the squirrel cage it should spin freely (if not add another drop to each part and spin the cage again). Reinstall the convection blower.
We can also provide information to test various parts of the stove if you are comfortable working with electricity let us know.
Then you can plug the stove back in.
ETA: If you don't have a leaf blower but have a very strong shop vac with a fine filter bag and a heppa filter attach that to the stoves vent as close to the stove as you can get it and use it instead of the leaf blower. Make certain that you have the correct filters or you'll have one hell of a mess and likely a burned out motor..
