iceman said:
why dont you guys call tech support of your stoves and find out.....
most stoves give you a cf number ... i was told that cf number is where the bricks are.. epa stoves can burn packed full ... but in order to get hot long secondaries you need some space up there.. if you pack your stove tight on a hot bed of coals and shut your air down after say 10-15 minutes you will prolly see your stack smoling for awhile until the height of the wood in the stove allows enough space/air to get those secondaries going.. now different stoves may operate differntly but with pe thats how they work.. with a downdraft stove (harman) you can pack it tight (they suggest you do) i find that when i pack the summit tight i really need to watch the air because the baffle and rails will start glowing if i am not really watching it ... when i try to keep it at the top of the bricks my light sshow starts faster and of course continues for a long time..... i will try to pack it and see during the daytime... but i know if i pack it e/w to the top of the bricks i get a longer burn time than n/s of course....
************ LMAO I JUST CALLED PE AND ASKED FOR TECH SUPPORT TO CONFIRM WHAT I WAS TOLD AND A LADY (THE SAME ONE WHO ANSWERED THE PHONE WHEN I ASKED FOR TECH SUPPORT) SAID THE CF IS THE WHOLE INSIDE OF THE BOX .. SHE SAID TAKE OUT EVERYTHING AND THATS 3 CF! SHE ALSO SAID FILL IT TO THE BAFFLE!
so i guess i stand corrected but i am calling tom
well i am going to stuff it and fine out
will report back tomorrow!
Fill it to the baffle, thats what the space is for.
It is NOT an issue about not enough air for combustion of the gasses. The Secondary is its own air source, not controlled by the lever.
The baffle has jets on both the top and front. And trust me on this one, even with wood up to the baffle, those jets will blast holes in the wood at where they exit.
To the original poster of the thread. So a smaller unit say like a Vista should only put a split in there? or 2 or 3 small pcs?
The firebox is its size for a reason. Same thing for your old smoke dragon. That box should be huge, and the reason is, back then, they got crap for efficiency, so the large area was loaded full to achieve long burn times. 3 splits in an old smoke dragon is going to go much faster than any new stove. Its burn and up the stack with no resistance and no secondary to burn the gasses off and gain that added energy.
The only time 3 splits go in this one, is in the shoulder seasons.
A full box does NOT equal overfire.
