I've been lurking around here for awhile and I've picked up some great info.
I will be installing a wood stove in my pole barn in the next week or so and before I start I wanna make certain I am doing things correctly. Attached is a diagram illustrating the job.
1. Do I need a ceiling mount box AND a chimney roof support bracket? Is the ceiling mount box drawn in the correct location?... on top of the metal ceiling attached to the truss with lumber.
2. Lowes says their double wall pipe has a 2" clearance. Does that sound right? Wondering how close I can install it to truss lumber and double bubble insulation under the roof metal. I can center the pipe between the roof girts (2x4's) if I have to, but if 2" clearance is correct, it will be easier.
3. Do I need double wall pipe from the chimney cap all the way down through the attic space to the metal ceiling? Or only through the roof?
4. What kind of caulk or sealant is recommended for the dektite and brace brackets? Is it needed anywhere else?
5. Should I install a damper? If so, where?
Thank you all for this great resource. It's much appreciated
![Stove install in pole barn Stove install in pole barn](https://www.hearth.com/talk/data/attachments/238/238812-4922f29eeeebe524aa3187235583a2eb.jpg)
