Greetings, I have small (12' x 16') uninsulated stick frame cabin with 10'-12' ceilings and a little sleeping loft. We currently have an old wood stove in there that is not very airtight. It is attached to stove pipe that goes up 5' or so, turns 90 deg and connects to a double-wall stainless chimney that goes through the wall and then up the exterior of the cabin.
Draft is strong and air access is plentiful even when fully closed down. This stove has no issue heating the cabin and will easily overheat it if you load too much wood. Its main problem is that we are lucky to get over 2 hours of burn time and will overheat the place to do so. However, once the fire goes out, due to its size and lack of insulation, the cabin gets freezing quite quickly.
I am looking for a small stove that costs $1000 or less. I'd like something that will close down very tightly, so that I can let logs coast through the night. I'm looking to open it up in the morning and throw on a log or two to get the fire going again, rather than build a new fire while I'm freezing in my jammies. I am used to waking up, seeing my breath, and having zero desire to exit the bed.
I realize this is not the best way to run woodstoves in terms of creosote, but the chimney is easy to clean and I would rather clean it more often and build fires while I'm freezing less. Ideally it would have a smaller firebox so I could run it hot during the day and not overheat the cabin.
