Pass the popcorn for this open can of worms! The replies to this should prove interesting if not even down right entertaining. I can assure you that the GB BB has already given you a “warped” sense of the term efficiency compared to most here. They just wouldn’t understand you. LOL!Hi all, I would like to know how to calculate the efficiency of a wood stove and on what is based the efficiency of a wood stove ! Thanks
Sorry but I can't understand your curious answer...Everybody want an efficient wood stove but how many really know and understand it? Is it so offendant to ask that question ? And what do you mean by : GB BB, has already given....show me please that answer, I don't really remember it . Thanks for your great kindness.Pass the popcorn for this open can of worms! The replies to this should prove interesting if not even down right entertaining. I can assure you that the GB BB has already given you a “warped” sense of the term efficiency compared to most here. They just wouldn’t understand you. LOL!
Wood btus loaded divided by btus to the room. Easy to say. Really hard to measure. Any epa rated wood stove an efficient enough for me.Hi all, I would like to know how to calculate the efficiency of a wood stove and on what is based the efficiency of a wood stove ! Thanks
OOPS, sorry for my answer, now I see what you meant, now I burn a Hearthstone Soapstone 8024. No more BB since a few Yrs. A bag was around $5.00 Can. when I began with anth. now it's over $20.00/bag ... As you can see, my English can be improved...Salutations from Québec.Never said it was offensive to ask the question. Never even implied it.
GB Base burner…did you use the base burner?
That is the basic meaning of it. But you also have to factor in unburnt potential fuel escaping the chimney as wellI know that many opinions exist about efficiency of wood stoves, complicated calculations seem to be made especially to give peace of mind for custommers and for stove makers, about like the same thing for the burn times in labs versus in real homes. For a 81% LHV efficiency , is the heat loss from the stove going to the stove pipe/out of the house is : 19% ? And for a 77% HHV efficiency : 77% stay in home and 23% go outside of the home % ???
Thanks, just to see for myself if I was right or fool about the efficiency meaning : I called many wood stove dealers and asked them the same questions about wood stoves efficiency and none had the same answers and didn't really know how how it works , so I can't imagine if asking the same questions on efficiency to ordinary stove buyers or stoves owners what would be the answers ???That is the basic meaning of it. But you also have to factor in unburnt potential fuel escaping the chimney as well
How are you measuring the temperature at 11 inches from the top of the stove? That is, what is the nature of your "STOVE PIPE thermometer"?...300*% F on the STOVE PIPE thermometer, at 11 inches from the top of the stove...
What stove do you have? How are you running it?With a magnetic thermometer on the stove pipe, placed at 11 inches from the top of the stove.
Hearthstone Heritage 8024. Usually around 350/ 400 * F on the top of the stove.What stove do you have? How are you running it?
Okay. Just keep in mind, you are not measuring the flue gas temperature. You are measuring (approximating, actually) the temperature of the outer surface of the flue pipe.With a magnetic thermometer on the stove pipe, placed at 11 inches from the top of the stove.
Ok but how far open do you have the air?Hearthstone Heritage 8024. Usually around 350/ 400 * F on the top of the stove.
Same thing for the thermometer on the outer stove 's top , measuring the outer too. You know, a stove pipe is so thin that it may not makes a very big difference , but I can do the same test with a probe thermometer, I have one on my Hearthstone Tribute stove pipe..Okay. Just keep in mind, you are not measuring the flue gas temperature. You are measuring (approximating, actually) the temperature of the outer surface of the flue pipe.
