[ I use a Harman SF360 boiler and burn a lot of Lodgepole Pinewood. It seems to be very inefficient when idling as most of the heat goes up the chimney, but burns clean and judging by the temperature gauge, pretty efficient when draft open. Looking at Garn (and others) that store the heat in large volumes of water, I am looking at 1000 gal. propane tank,standing at a 45 degree angle, welding in outlets, bottom and top, a couple for aquastats and storing water at 180 to 190 degrees. That should be between 250,000 and 300,000 btu. Then I could run boiler in most efficent mode and heat would last from 24 hrs to 2 or 3 days depending on weather. It could still be a closed system, 20 psi, etc.
Anyone have experience doing this? Idea's?
The tank is free, good condition, but welding, insulating and housing are far from free.
Robby
Robby
