Gboutdoors
Burning Hunk
I use mice to eat what few bugs are in my stacks. Then the snakes eat the mice. Then the owls eat the snakes. Then I burn the wood. It's called the circle of life.
Just sprinkle it on and around your wood piles. Way too much information out there to try and pick one single link to post. Just google "food grade diatomaceous earth bug killer"This is what I use for my pool filter, and I have a ton of it. How can it be used for bug control? Never heard of it used that way.
Hell, some people even eat the stuff if it's food grade. It's that safe. (Not that I do though)Diatomaceous earth is a fine abrasive. It abrades the joints of insect wings and legs I believe. It's fairly benign in humans until you breath the dust. Then it's very bad. I can't see how it would be very useful to control insects around a woodpile.
TSP in solution at almost any concentration will carry a pH less than 10.0, much less than NaOH. It is not at all corrosive, you have that part backward.
TSP is not a liquid and will not form a gas that is easily transported through your chimney to affect anything in it so unless there is some other ingredient that the TSP interacts with to form a gas (fumes) you are probably going to be sweeping raw TSP from the stove after you use one of those dubious snake oil products.
As far as common chemicals present in a stove burning carbon in the presence of air and thus benign, consider the 2 most abundant chemicals in the stove, carbon and the 80% of air that is nitrogen. A direct reaction between those chemicals makes cyanide, CN. I know how dumbed down some arguments of "natural food advocates and tree huggers" has become but just because the components are shared with something in your stove does not mean I want to be exposed to it, even in low concentrations.
I can handle anything anything but spiders and snakes, I'll be flipping logs over with a rake.
What material are you using to cover your stacks?Nice of them to stop by
