Did a search on this topic and didn’t see much. So here are my questions. I installed a steel wall behind my stove. It’s black roofing steel and it has a 1 inch air gap between the drywall and the steel. For some reason I can’t find ANY topic. (Here or online like Reddit or fb woodstove groups). I see many who have steel walls behind their stoves but no one giving opinion on how hot they get or how hot they shouldn’t get. I had my Huntsman stove 20 inches away from the steel and when I had my stove putting out max heat (which was 650 off the top and 550 off the sides) the steel directly across from the stove woukd get as hot as 195. And never showed any issues. I’m installing a new stove. A Fisher Teddy bear that has the heat shield on back. I’d like to get it as close to the steel as I can. So I’m looking for any opinions. I’m pretty sure I think I know what I can get away with already but figured I’d bring this question here.
Just want to add I homestead and do NOT have insurance or codes I have to worry about. But I DO want to be safe. I was thinking of adding another section of steel over the existing steel wall and leaving an inch air gap. That would be two sheets of steel with 2 inches of air between them. I’ve tested the steel and it can get well close to 300 degrees with no issue. Please drop me your ideas.
