What is wrong with poured crowns?Im not a big fan of floating crowns but i still do them. As well as crown splashes
We wont do wash crowns. I just cant justify charging for such a temporary fix.
What flashing is that?
Is it physically possible??? Absolutly...my nose has gotten wet carrying an umbrella while it was raining. I can verify that it didnt get wet during the storm that hit about 20 minutes after i finished tuckpointingI am sorry but rain can absolutly get to that lip.
Ok one storm didnt hit it.Is it physically possible??? Absolutly...my nose has gotten wet carrying an umbrella while it was raining. I can verify that it didnt get wet during the storm that hit about 20 minutes after i finished tuckpointing
Nothing is wrong with poured crowns. Just not my preference.What is wrong with poured crowns?
Heres a 4" skirt
You really need to get that old mess out of there.Thanks for the photo! That's sort of like what I was thinking to use.
My problem is the existing crown dips 2 1/2" inches from peak so I have to add that to my skirt height just to get to the brick.
I would say 30 years is pretty good for that construction. That is about average size for a fireplace chimney around here. Is it abnormally large for your area? Just curiousGuess I'm concerned if I start demoing the concrete crown I'm going to damage and loosen lots of brick below. I suppose if they get loose it means they need replacing anyway, but why look for more trouble on a 33 year old mammoth chimney?
From what I read 30 years is not bad for exterior masonry to last in this climate.
But yes, it is kind of a sorry mess![]()
Not uncommon at all here. Mine which has 2 flues is 9x3.The chimney sweep who saw it (in business for 30 years) said its one of the most rediculously oversized chimneys he ever saw. It only has one flue down the center and is 6' x 3' wide. We do have chimneys in the area this big, just not with only one 13" x 13" clay liner.
I dont know i didnt build it lol. Mine is just straight up with no shoulders but it is still bigger than it needs to be. But not uncommon in this area.Why so much masonry for only two flues? Asthetics? 9 feet - really?!?!?
If you do add a layer of brink and you dont plan on filling in with mortar to make a nice flat surface for the chase cap to fit on you could always get some hardyboard and some quad iso, silicone, geocel 2300 or whatever you like and glue it down. Throw a couple tapcons in it if you want or double it up. Then just put the chase cover over that.Thanks for the photo! That's sort of like what I was thinking to use.
If the numbers work out right I might just add another layer of brick all the way around so that I can go with a smaller skirt.
At that size with as much as your chimney sticks up roughly 5" would be the max i would do. Blazing can make fun of my degree all he want but the wrok i do looks good because of it plain and simple.That's a really great idea. That solves some of my problems with the crown and brick height issues.
I think the hardyboard would have to be supported with some angle iron over such a long 3 foot span.
How long of a skirt starts to look bad on a 6x3 foot chimney?
Because your existing crown sticks up to high so you will need a big silly looking skirt on the stainless top plate. Unless you build up around that crown with brick which if you are doing that why not just pour a crown afterwards.I thought you said the stainless cover works well? What's bad about leaving the old crown and using a chase cover?
Ok fair enough i apologize for my comment.Im not making fun at ur degree as u probably worked very hard to get it and it obviously serves u well and probably gives you an edge over most others like myself on subject matters related to design. I was however giving you a hard time because of the way it initially read but i assumed a casual setting and really didnt mean anthing by it. Ill drop it. If it were me i would do what pthers have stated but hes already addressed not wanting to go thru that as he might not feel comfortable doing the repairs so i was tryong to come up with a easy alternative. As far as supporting it, all i really meant was make a judgement call if u think it needs to be supported it probably does
