Have learned a ton from this site and I wound up purchasing an F3CB on clearance....10% off. So thank you everyone!
Before I have it installed, I would like to put up a stacked stone veneer on most of the wall behind where stove will go before stove goes in (will leave space for pipe through wall).
1 - What are your thoughts on applying thinset to adhere stacked stone to wall...Apply directly to painted sheetrock? Install wire lath over sheetrock first? Or install Hardibacker (instead of wire lath) over sheetrock first?
https://www.msistone.com/hardscape/rockmount-stacked-stone/
As per MSI, they recommend Prolite thinset by Custom Building Products. I’m guessing I should follow the instructions as per the thinset manufacturer.
2 - Do I need to consider expansion/contraction of any stone product on wall in close proximity to stove? Might stones pop off after a while?
Hoping to tap into your experiences...thanks again.
Chris
Chris
