I did shorten up the exhaust run quite a bit... i dont know if what i have is still considered a long horizontal run or not though.. I have 1 foot out to a single cleanout tee then up about three feet then a 90 degree angle to 3 feet out of the house plus another foot to the term cap which is 45 degree. Would you think that is a long run or pretty average? Its in the basement so really was best i could do.The manual states if you have a long horizontal run, then you will need more to open the damper. If I remember correctly, your horizontal run used to be quite long but you got it shortened up. If that is the case, you probably won't need as much air as it used to take.
Also does anyone know for the draft trim that is set on heat level 1 if upping the voltage is only in effect when on heat level 1? i have read the manual but not really clear if thats whats happening.
