St Croix Igniter trouble.
Smokey,imacman
Thanks for posting what the igniter resistance would be ,around 50 ohms.
Attila (spelled it right this time!),
If you want check igniter resistance and your meter , here would be procedure
(apologize, should have thought of this sooner). ----------
Not to have ya run out and buy more stuff, but do you have a known resistor handy ?
If not, grab a couple of CHEAP 500 ohm resistors from radio shack or electronic store.
Check the igniter that you have out of stove, then check igniter that is in the stove.
use your x1k range and measure resistor . should deflect to 5(500ohm) . whatever it deflects to is
the baseline resistance. if no measurement here ,try a couple of the resistors, if still no measure,
return the meter and demand your money back ! buy a cheap Digital meter at this point.
Then tie one lead of resistor to meter lead, other lead of resistor to igniter .
Then tie other side of igniter back to meter (series connection).
If no deflection measurement , then igniter open ? Otherwise should read baseline resistor+igniter resistance
500+50 =550 ohms or so.
THEN
igniter in stove check.
POWER OFF !
UNPLUG !
disconnect igniter and do same procedure, putting baseline resistor in series with igniter.
That should show igniters, unfortunately sounds like both open ?
Anyway post with progress.
Also one might ask - why a series resistor ?
Well, trying to measure 50ohm on 1000 ohm scale might be difficult.
Analog meters are normally more accurate at high % of deflection scale,
so a more accurate measurement would be taken at 550 ohms than 50 ohms.
Also this checks the meter.
Good luck !
Returned the the igniter for a different one.
Tested before I put it in and acually got a resistance reading.
Installed it and everything is working fine!!
Amen!!
Thanks for all the help!!
